hey,
i draw a few points on a dem raster,
than with the help of the tool add geometry attributes i added to the attribute table X,Y and Z coordinates.
when i open the attribute table i dont get the Z value.
P.S
in the map properties i added the correct vertical coordinate system.
the main issue for me is to get the Z value in a 2d map and not in a 3d map.
you can view the img that describes the issue here:
thanks.
Solved! Go to Solution.
Elevation sources are added to the elevation surface (Ground) in a map through the add data dialog.
https://pro.arcgis.com/en/pro-app/latest/help/mapping/properties/elevation-surfaces.htm
