Year only in a date field
14298
16
04-17-2019 10:57 AM
JoeBorgione
I have a feature class with a numeric field representing a year in the form of yyyy (2017).  ArcGIS Pro has a tool called Convert Time Field that can take an integer and write it to an existing date field or it will add one for you.
When I run the tool it returns a date in the form of 1/1/2017.  Is there a way to format a date field to show just the year?
Robert_LeClair
Esri Esteemed Contributor
If you added a new text field and calc'ed that field to have the year only?  Would that work?
DanPatterson_Retired
You missed my "Funky" link above.  Apparently a text or numeric is not needed, but a Date field with just the year... cool results though
Robert_LeClair
I did - cool "funky" link though!
JoeBorgione
Probably; this is a project wrought with bad data, so any additional fields are just a band-aid at best.  My colleague found something on github that he's working through.  We are seeing more and more non-data types who want data-intensive analyses.  Not a great combination. (Can't you just hit cntrl F3 and make my spreadsheet a bomb-proof database?)
AlexZhuk
I think there is a misunderstanding between the core properties of the Date, Text, and Integer types. Or it's just my misunderstanding?
JoeBorgione
Not really a misunderstanding per se, just wondered if it's possible some how.  I guess it's not and as mentioned earlier, this red herring is back into the sea......
by Anonymous User
Not applicable
Some of my favorite problems to have: 1) writing code for rotational corrections brought over from legacy CAD files 2) commingling scalar & vector "man behind the curtain" magic to represent velocity arrows at the requested scale that originates at a fixed point, and 3) Dealing with date conversion for client display. Just kidding, all of that gives me a headache but date management is something you have to start managing the expectations of your users (and boss) on and start looking for stronger typed  solutions that offer better management of date & time with built-in functions for your chosen flavor of RDBMS. If you don't have options on those fronts, DatePart is a handy function to gain familiarity with for popping the date into a text field. Big picture advice - educate yourself on date field manipulation because it's worth getting your head around.
