I'm trying to plot Lat / Long points from within an SQL view table and when I do, the tool runs until 95% completion, where it then stays indefinitely. The parent SQL table is live and being updated in near-real, so perhaps the issue is due to the ever increasing volume of data. My plan is to query records that are within the last 48 hours so as to greatly reduce the volume. I was curious if anyone else has experienced this issue, and if so how you were able to correct it?
Did you ever find a solution for this. I'm having the same issue, but mine gets stuck at 100%.
