XY Data projecting in the wrong place, need another opinion
1153
05-21-2020 09:11 AM
AnthonyPodesto
The lat/long data is correct and have checked everything I know of.  Need to give my brain a break.  Any other ideas out there?
Thanks, Anthony
Robert_LeClair
Esri Esteemed Contributor
When you use the XY Table to Point geoprocessing tool in ArcGIS Pro, are you selecting GCS_WGS_194 for the Coordinate System Parameter?
AnthonyPodesto
Yes, it comes up as the default.
Robert_LeClair
So I tested a few of the XY coordinates and as you said, they are truly located in CA.  What I would do for a test is open a new 2D Map View in the Pro Project, add the Table, and run the XY Table to Point GP tool using the WGS 1984 coordinate system.  Does the newly created feature class line up as expected?  Please advise.
