Why is ArcPro renaming my raster files??
1544
05-14-2019 10:56 AM
JessicaClements
I am working on a project where I am georeferencing raster images and then moving them to a "complete" folder. Sometimes, when I move the images, arcPro changes the name of the files and adds a "c" at the beginning. It also seems as if it has combined some of my files that have similar names. Does anybody know why it does this??
MervynLotter
MVP Regular Contributor
I suspect you are using a number at the beginning of your raster name? If so Pro will add a letter "C" at the beginning of the name instead of throwing out an error.
JessicaClements
Interesting. But it hasn't done this for other files? Those other file names, even though they also started with numbers, remained the same.
MervynLotter
I generally work with a file geodatabase or other files stored locally on my computer. I am unable to create a raster that begins with a number in either the a file geodatabase or a file stored on disk (like a TIFF file).
Similarly I am unable to create a feature class in a file geodatabase if the feature class begins with a number. Only if I export to a shapefile can the file begin with a number.
