Why can’t ArcGIS Pro Action AI Assistant open Geoprocessing Tools even after being prompted?
323
3 weeks ago
RahmatFaisal
I’m experiencing an issue with the AI Assistant in ArcGIS Pro. When I ask the assistant to open or run any geoprocessing tool (such as Buffer, Clip, or Spatial Join), it does not respond to the command — the tool window does not open, and no process is executed.
Is there any additional configuration, permission, or setting required for the AI Assistant to access or execute geoprocessing tools?
Or is this functionality not yet fully supported by the AI Assistant in the current version of ArcGIS Pro?
Thank you for your help.
DanPatterson
If this is the one you are talking about, it seems its current functionality is limited
ai-assistant-pro.pdf
... sort of retired...
RahmatFaisal
However, in the following demo video, at 4:03👉 https://youtu.be/G0_PZrD8j2Q?t=243
the presenter shows that the AI Assistant Action can successfully open the Geoprocessing Toolbox window.
In my case, when I try the same prompt, the toolbox window does not appear.
In this video from Esri UC 2025, Jess Altamira and Caitlin Marin demonstrate three new deep learning tools in ArcGIS that accelerate spatial analysis. You will learn how to use GeoAI to train models and detect road damage, see how the ArcGIS Pro AI Assistant finds and runs geoprocessing tools with
DanPatterson
assuming you are part of the Beta program and have it configured to use it, this is the only other documentation that I can find at this time
Pro 3.6 is due to be released soon so perhaps it will be out of beta and will be installed fully at this release
VedantBajaj
Hi @RahmatFaisal, for questions related to the ArcGIS Pro assistant (beta), can you post your questions to the Early Adopter Community Forums?
