I’m experiencing an issue with the AI Assistant in ArcGIS Pro. When I ask the assistant to open or run any geoprocessing tool (such as Buffer, Clip, or Spatial Join), it does not respond to the command — the tool window does not open, and no process is executed.
Is there any additional configuration, permission, or setting required for the AI Assistant to access or execute geoprocessing tools?
Or is this functionality not yet fully supported by the AI Assistant in the current version of ArcGIS Pro?
Thank you for your help.
