When I try to repair or change data sources, I don't have an option to use a source that has been saved in my local profile favorites dialogue. Am I missing something in my profile configuration or is this by design? (See screenshot)
After working with ESRI Support, they showed me a way to get my favorites to behave the way I would have expected in the first place.
Go to your Favorites Pane and right click on each item to select "Add to New Projects"
Now they are available!
A somewhat related "Idea"
Make Folder Favorites References Again! - Esri Community
and you might want to see if there are some that match
Matt, that drives me nuts. I know Repair Data Source isn't the only place that does that, but I can't remember at the moment where. According to a comment on that ArcGIS Idea, they thought that a fix would be in Pro 2.9, but I'm using that right now and it's still not an option. At least it's on their road map.
Sweet. Thanks for sharing!
