Why aren't more ArcGIS Pro bug reports shared publicly?
20292
38
02-10-2023 07:06 AM
Bud
Legendary Contributor
In the past months, I've submitted some new bug reports:
  1. BUG-000155584 - View on FGDB standalone table gives error “Failed to add data, unsupported data type.” while adding to a map
  2. BUG-000155660 - Definition queries do not appear as active after enabling the query and reopening the definition query again
  3. BUG-000155377 - Unable to create a bar chart on a database view created in a mobile geodatabase
  4. BUG-000140702 [re-opened] - Right-clicking and selecting paste does not work when attempting to paste a value into the query builder in the Select By Attributes tool
    Edit: And a few more:
  5.  BUG-000150273 - ST_Geometry functions applied to the Shape field in Select By Attributes return the error message, "Error 000358: Invalid expression" if the feature class is registered as traditional versioned.
  6. BUG-000155819 - Attribute table of joined layer in Mobile Geodatabase does not open when a definition query with a subquery is applied to the join table.
  7. BUG-000155830 - Failed to open Mobile geodatabase feature attribute table after applying join from a SQL queried standalone table with error: Underlying DBMS Error [ambiguous column name objectid]
  8. BUG-000155888 - In the Create Database View geoprocessing tool, the Output View Name parameter is cleared when the first click after entering the Output View Name occurs outside of the tool interface.
  9. BUG-000156143 - An SQL query containing the EXISTS predicate validates successfully but returns incorrect results from a file geodatabase
  10. BUG-000156405 - Validate Join message is incorrect in ArcGIS Pro when Add Join to table or feature with Definition Query within the same workspace.
  11. BUG-000157223 - The View Icon shows as Standalone table instead as Feature Class in Mobile Geodatabase
  12. BUG-000156931 - Unable to select features using the Explore or selection tool from a view in a mobile geodatabase in ArcGIS Pro.
  13. BUG-000157376 - Unable to select features using the Explore or selection tool from a view with a join in a File geodatabase in ArcGIS Pro
  14. BUG-000157475 - Cannot open table from the Catalog pane for a spatial view found in a mobile geodatabase.
  15. BUG-000157568 - In ArcGIS Pro, when a file geodatabase is placed in a file folder that contains .gdb in the folder name, you cannot add new feature classes, feature datasets, tables, etc...to the file geodatabase.
  16. BUG-000157571 - When running the Make Route Event Layer tool, the Layer Name or Table View default to the table owner instead of the table name in Oracle Enterprise Geodatabase
  17. BUG-000157565 - When running the Make Route Event Layer tool, the Layer Name or Table View default to the table owner instead of the table name in Mobile Geodatabase
  18. BUG-000157718 - Excel to Table tool prefixes table name with "main.main_" when importing to mobile geodatabase
  19. BUG-000157719 - Excel to Table tool prefixes table name with table owner when importing to Oracle enterprise geodatabase
  20. BUG-000157728 - Creating a new geodatabase in a favorite folder causes Catalog to expands multiple folders
  21. Internal Esri GitHub bug reported: ‘Progress Indicator not showing in catalog when creating new mGDB’ [Esri Case 03318871]
  22. BUG-000157736: Create Database View geoprocessing tool returns incorrect data when SQL CASE expression returns a text value in the View Definition parameter
  23. BUG-000157874 - Sorting fails after a Flag field is added to a view definition, the view is joined to a feature layer, and the Flag field is moved to the front of the table
  24. BUG-000157875 - Remove Join tool fails after a Flag field is added to a view definition, the view is joined to a feature layer, and fields in the joined table are reordered and sorted
  25. BUG-000158141: The cardinality of a join is incorrect in the Layer properties for 1:1 joins in ArcGIS Pro 3.1
  26. BUG-000158140: ArcGIS Pro: Join from table to database view generate Join fields with null values
  27. BUG-000158324: Mobile GDB view definition contains "CREATE VIEW [name of table] AS" , whereas File geodatabase views and enterprise geodatabase views do not.
  28. BUG-000158187: When using "Truncate Table" with a table that has a join, ArcGIS Pro provides an incorrect error message of "001400: Only the data owner may execute"
  29. BUG-000158857: When renaming a table or feature class in a mobile geodatabase in ArcGIS Pro, the selected rename text displays the previous attempt at renaming, even if the attempt failed.
  30. BUG-000158912 - User with ArcGIS Pro 3.1.2 and mobile geodatabase can't save field alias using same name as field for their standalone table.
  31. BUG-000159358: Delete option is available in the attribute table for a field of a joined table
  32. BUG-000159633: In a mobile geodatabase table in ArcGIS Pro, the field alias gets automatically set to the previous field name.
  33. BUG-000159170 - ArcGIS Pro 3.1.2 - Unable to sort joined fields when a mobile geodatabase standalone table is joined to a mobile geodatabase feature class in a 1 to many join.
  34. BUG-000160320: Slow performance in Pro when interacting with the attribute table of data which participates in a join.
  35. BUG-000158623 - ArcGIS Pro - The 'Move to End' button within the Attribute Table does not work as expected while working with tables from regular databases or mobile geodatabase.
  36. BUG-000160924 : SQL query becomes case sensitive when a Feature Layer is joined to a table stored in a Mobile Geodatabase. After joining a feature layer and a table (both stored in a Mobile Geodatabase), SQL query becomes case sensitive and the previous SQL query expression fails to execute.
  37. BUG-000163083 - ArcGIS Pro does not honor the Allow NULL value that is set for the SHAPE field during feature class creation.
  38. BUG-000163402: Double click is required when adding new rows to the attribute table of a feature class that has no user defined fields.
  39. BUG-000163640: SQL Expression applied to the Shape field in Select By Attributes returns the error message, "Error 000358: Invalid expression" if the feature class is registered as traditional versioned.
  40. BUG-000163772: Views in file and mobile geodatabases do not indicate in their Data Source properties if they have been registered with the database
  41. BUG-000163754 - Catalog item properties of FGDB (and Enterprise GDB) database view: "Manage" options (Attachments, Global IDs, & editor tracking) should not be available
  42. BUG-000163933: ArcGIS Pro 3.2 - Appending data from a file geodatabase feature class to a table using matching fields for update throws the error "Error 000229: Cannot open TABLE" despite successful append/update.
  43. BUG-000164071: In ArcGIS Pro, when using the Table Select (Analysis) tool, the Mobile Geodatabase prefix is used as Output Table instead of original Feature Class name
  44. BUG-000164132: The 'Clear' button under the Contents pane selection tab is missing when selecting zero records in ArcGIS Pro
  45. BUG-000164133: The clear button is grayed out when selecting zero records and ensure consistent behavior for the clear button in ArcGIS Pro
  46. BUG-000164128 Unlike ArcGIS Pro 3.1, when importing a Display Filter file in ArcGIS Pro 3.2, the feature layer is not automatically updated according to the imported file.
  47. BUG-000164177: Database Views show SELECT, INSERT, UPDATE, and DELETE Privileges in the Data Source properties
  48. BUG-000164343: ArcGIS Pro 3.2 - The field name in attribute table does not update after applying SQL expression when creating database view in File Geodatabase
  49. BUG-000164295: Sorting a field removes rows from an attribute table with a one-to-many join between a feature class and a standalone table in a mobile geodatabase.
  50. BUG-000164393: The Add Spatial Join tool returns ERROR 000728 when applied to a feature class stored in a Mobile Geodatabase or EGDB
  51. BUG-000164420: Database View created in file geodatabase with Join definition does not create the required duplicate fields
  52. BUG-000164429: When creating a database view, using a cast function in the where clause results in an error
  53. BUG-000164631: Attribute indexes generated on fields participating in an inner join for the creation of a file geodatabase database view
  54. BUG-000164707: In ArcGIS Pro 3.2, there are some geoprocessing tools (such as "Make Feature Layer" or "Make Table View") that have a parameter with a note saying "This parameter is not used". This parameter does not cause any direct issues, however it is confusing and counter-intuitive to clients.
  55. BUG-000164755: The field is not populated when CAST is used with a file geodatabase with "Create Database View"
  56. BUG-000164759 - The "Make Table View" tool output doesn't include a Query section in the Table Properties if the Input table is an unregistered table picked via the Folder Icon.
  57. BUG-000165217 - When a relate exists between a table and a query layer with a composite key joined to another table, related records are not displayed if the query layer name contains a space.
  58. BUG-000166125: ArcGIS Pro 3.2.2 - Make Query Table Tool joining all tables despite selected records
  59. BUG-000167214: Attribute Indexes in a Mobile Geodatabase reappear after deletion in ArcGIS Pro.
  60. BUG-000167373: Query Layer with WHERE clause does not show full query in Diagnostic Monitor
  61. BUG-000167456: Copying or exporting a feature class into a non-EGDB Oracle Database results in long integer fields being displaying as Big Integer in the Fields View
  62. BUG-000167563: Join with definition query doesn't export the correct number of records, instead it exports all the records.
  63. BUG-000167610 - The Create Unregistered Feature Class geoprocessing tool does not honor settings like Geometry Type, Has M, Has Z, or Spatial Reference while creating the output.
  64. BUG-000167752: Misleading error message returned by Copy tool when only the path the to GDB is input without a feature class name.
  65. BUG-000167802: ArcGIS Pro - Can't copy text from geoprocessing input parameter using right-click menu.
  66. BUG-000167962: ArcGIS Pro 3.3 - Wrong context menu options displayed for standalone table in contents pane.
  67. BUG-000168565 - The Find Identical geoprocessing tool auto-populates the Output Dataset name with the data owner name instead of the feature class name when the Input Dataset is picked from the drop-down of the layer list from the map.
  68. BUG-000168914: Error "The SQL expression has invalid syntax" is encountered when a subquery is used on an unregistered table, query layer, or unregistered database view.
  69. BUG-000169056: “ERROR 000358 DBMS table not found[ORA-04043: object xyzx.xyzxy does not exist]” is encountered when using "Make Aggregation Query Layer" tool with Oracle geodatabase.
  70. BUG-000169250 - The Make Aggregation Query Layer geoprocessing tool does not recognize 64-bit Object ID (bigint) as a unique identifier.
  71. BUG-000169342: In ArcGIS Pro when a join is created between two query layers where the second query layers was copy/pasted from the first query layer, there is no reference to the second query in the join properties.
  72. BUG-000170076: Unable to alter the Alias of a field for a registered View via the Fields menu in ArcGIS Pro
  73. BUG-000170416 - The Assign Domain To Field tool fails with "ERROR 000499: table is not editable" while working on views registered with the file geodatabase.
  74. BUG-000170482: When running the Spatial Join tool in Pro, the output feature class name defaults to include the data owner, not the feature class name.
  75. BUG-000170592: ArcGIS Pro's DRA function is highlighted as enabled for raster symbology that does not support DRA.
  76. BUG-000170631: Tables in mobile geodatabase cannot perform one-to-many joins using Add Join geoprocessing tool in ArcGIS Pro.
  77. BUG-000170869: Adding a definition query excludes a row of data when using Add Join geoprocessing tool in ArcGIS Pro
  78. BUG-000171002: Mobile Geodatabase Table Views recognize ObjectIDs as Long (in version 2.9.5) or Big Integer (in versions 3.3.1 and 3.3.2), instead of the expected ObjectID data type.
  79. BUG-000171080: In ArcGIS Pro, when resizing a column in the attribute table by double-clicking on the boundary between two columns, the resize does not stay after refreshing the table.
  80. BUG-000171084: Selecting the "Run" button of geoprocessing tools in ArcGIS Pro through the tab button shows a faint highlight compared to the expected, bolder highlight.
  81. BUG-000171301 - ArcGIS Pro fails with "ERROR 160195: An invalid SQL statement was used." when the Make Query Table tool is run on a Query Layer.
  82. BUG-000171586: Compression Quality when using Export Raster does not honor the range from 0 to 100
  83. BUG-000171969: Inconsistent Join Operation behaviour when joining tables with definition query in ArcGIS Pro
  84. BUG-000172709: Generate Definition Query From Selection geoprocessing tool includes a toggle to deselect selections. When disabled, it causes the tool to fail.
  85. BUG-000172724: Generate Definition Query from Selection geoprocessing tool documentation does not specify which data types are unacceptable and why.
  86. BUG-000173164: In ArcGIS Pro, the Select by Attributes tool removes the leading space from a value in clause-mode, but not in SQL-mode.
  87. BUG-000173175: In ArcGIS Pro, Select By Attribute with an empty clause or SQL expression will select all the records in a table.
  88. BUG-000173762: In ArcGIS Pro, the Add join tool creates a one-to-one join when the join is created between a Feature class and an unregistered view, even when one-to-many cardinality exists between the data.
  89. BUG-000174348: Contents Search does not filter standalone tables in ArcGIS Pro
  90. BUG-000174199: Inputting a domain name with length greater than 255 characters causes Pro 3.4 to crash.
  91. BUG-000174360: When using the Export Raster geoprocessing tool, if the operation gets canceled, then the Output Raster Dataset parameter gets reset to the original value.
  92. BUG-000174631: Entering a line break into an Attribute Table cell value using Shift+Enter works for the first edit but not for subsequent edits.
  93. BUG-000174722: In ArcGIS Pro, it is not possible to copy a portion of a text value in a layer's attribute table using a mouse.
  94. BUG-000175441: Clicking and dragging row headers in the attribute table to select multiple rows causes the table to scroll left.
  95. BUG-000176895: When a join exists between a table and a feature class in an enterprise geodatabase, 'Select By Attributes' takes a long time to load the results in the attribute table
  96. BUG-000184633: Edit widget in ArcGIS Experience builder does not copy attachments when using the copy/past feature and does not allow you to add attachments until creating the point.
  97. BUG-000184634: Synopsis : Pressing the “Windows + :” shortcut does not insert symbols into text fields within the ArcGIS Pro attribute table.
When I google those bug report numbers, I don't get many hits.
Question: Why aren't those kinds of bug reports publicly available?
  • For people who are googling issues online.
  • For people who don't have access to their organization's My Esri account.
    • Often, only IT staff at an organization have access to their organization's My Esri account. There are lots of Esri users like me who work in departments other than IT and, therefore don't have access.
Thanks.
Tags (1)
JoshuaBixby
MVP Esteemed Contributor
@ChristianWells , you seem to understand the support and defect processes well, so maybe you can have some influence on the following.  It would be great if the URLs for bugs and defects were decipherable from knowing the bug or defect.  For example, BUG-000094271 has a URL of support.esri.com/en/bugs/nimbus/QlVHLTAwMDA5NDI3MQ== .  Whatever the rhyme or reason is behind turning "BUG-000094271" into "QlVHLTAwMDA5NDI3MQ==" isn't documented anywhere.  For an organization with tens of thousands of GIS users that logs 50-100 defects and enhancements a year, linking internal documentation to Esri Support documentation is a very manual process.  It would be nice if one could determine the URL by knowing the BUG or ENH number.
Update:  For My Esri, both the old/classic UI and the new UI support URLs that are derived directly from bug or enhancement numbers.  For BUG-000094271 and the My Esri classic UI, the URL is:  my.esri.com/classic/#/support/bugs/BUG-000094271
ChristianWells
Thanks, @JoshuaBixby - this feedback is helpful, and I will share it with our web team for the support website. I'm glad to hear it's consistent for My Esri.
Bud
@JoshuaBixby, like you mentioned, the bug numbers are in the URLs now. Nice!
support.esri.com/en-us/bug/the-attribute-table-of-a-joined-layer-in-a-mobile-geoda-bug-000155819
https://support.esri.com/en-us/bug/the-attribute-table-of-a-joined-layer-in-a-mobile-geoda-bug-00015...
Bud
Why are some bugs googleable, like this one: BUG-000085841
But other bugs aren't googleable, like this one: BUG-000140702 ?
While that bug does have a permalink in the Esri Support Search site, I don't get any hits if I google the bug number or bug title.
ChristianWells
Thanks, Bud - I reached out to the web team on these as examples and waiting to hear back.
ChristianWells
I heard back this morning, @Bud - it sounds like they are already aware of the issue, and it's related to bugs going through the review and edit process multiple times. However, it is on their roadmap as they migrate the site to a new platform later this year.
In addition, @JoshuaBixby asked about the URL with the bug number instead of a GUID. This URL change is also planned for the new site migration and will help with SEO indexing.
Timelines can change, but this is being tracked, and I want to close the loop with both of you.
JoshuaBixby
Christian, thanks for the updates.  Here's hoping "later this year" is more like summer than 12/31/2022. 🙂
ChristianWells
Bud
Here's an example of a bug I reported 9 months ago, but it still isn't available on the Esri Technical Support website: https://support.esri.com/en/search-results#search?q=000150273&content-type=Bugs
Reported: June 24, 2022
I'm told the bug is still "In Review". Does it normally take that long for Esri to review bugs?
ChristianWells
No. I looked at this on our internal system - this bug was reviewed in July 2022 and marked as published around the same time. I will reach out to the web team for troubleshooting.
