What is ArcGIS Pro's Logic for Drawing a Parallel Line at a Specific Distance?
2899
11-30-2017 08:14 AM
CheyneHadley
Seriously, I can't figure out how ArcGIS Pro decides which direction to draw a line.  When I draw a parallel (or perpendicular) line, I press "P" (or "E"), then "D" for distance enter in a value, then ArcGIS Pro always draws the line in the opposite direction I want.  Watch the video.  I put in positive 1000 varas twice, but each time it draws the line in a different direction.  Why?  I always end up having to do this two or three times for each polygon because I have no idea where the line is going to go.
arcgispro editing‌
parallel‌
perpendicular‌
measured distance‌
by Anonymous User
Not applicable
It looks like you found a bug with parallel. The parallel option is internally setting the sketch direction constraint to the direction of the segment you clicked on (polygons segments are ordered clockwise). When the distant option is chosen, its using that direction constraint rather than the relative mouse location to determine the next sketch segment.
Good find, we'll get it fixed.
by Anonymous User
Not applicable
by Anonymous User
Not applicable
Fixed for Pro 2.2, it was too late for 2.1 (soon)
CheyneHadley
Fantastic to hear, thank you.
JMcCoy
How do you constrain a line parallel to another segment of the feature you are creating?
