ArcGIS Pro 3.4.0
My experience is that georeferencing is buggy in Pro.
What file type is the most stable? TIFF? FGDB? Something else?
Hi @Bud For imagery & scans out of a pdf I use a simple open source pdf to jpg converter then clean & clip as needed. Some PDF tools try to be 'smart' and add junk to tiff output. Tiff is great when Esri/Erdas/etc make it but not something I go to in the same sentence as pdf.
When you convert said tiff to jpg (not sure what Paint does - I prefer IrfanView for basic raster/bmp handling) it may also incorporate some of the 'bad' metadata from the tiff hence issues. The breaking of georeferencing may be due to a resize in the convert process. More reasons exist.I use png, jpg, jp2000, ecw, and tiff often and usually issues are created at the source and not in Pro; but Pro is less than graceful in handling these mal-formed datasets.... Sounds like an Idea.....Depending on the size I store a lot of raster data in FGDB. Fantastic placebo performance in my setup and it is a native format that Pro should work with without fault; it's also without weird issues like sneeze deleting the georefence file (not that I don't have easy nearline snapshot backups, but if I don't have to spend 2min restoring a backup....).
Thanks @RichardHowe.
Issues (Pro 3.4.0):
Now that Pro 3.4.2 has been released what issues do people still have that are not yet addressed?
PDFs definitely have some bugs in them. For the most part I have found jpgs to behave themselves thoughWhat issues are you having?
