Way to convert labels in a map layout frame to be features?
411
04-05-2025 04:16 AM
GeorgeJonesRIGOV
I'm just wondering about that. Had a bunch of maps to print and every time i slightly moved the map frame , the manual added labels would get displaced. Is there a tool like label to feature? I did convert labels to annotation and was not satisfied with that.
Tags (1)
JamesHood
It sounds like what you are describing is having placed labels in the layout view  and so when you pan the map in the map frame the labels no-longer represent spatially where they were placed.   they now appear to be placed elsewhere?
To avoid this if placing labels I would place therm within the map frame, or create features in a feature class or create them as annotations.
Converting to annotation should be possible  and should make them maintain their spatial reference so long as you select the correct map frame to place them into.
If you wanted to go a step further you could convert the annotations to points then label dynamically from points, depending on what you need to accomplish and what your work flow is.
It might be easier to just create a new annotation feature class and manually place the label annotations where you want them.
