Valid 3D Tiles service fails to draw in ArcGIS Pro 3.2.1
1890
01-02-2024 07:44 AM
EricEagle
I have a valid version 1.0 3D Tiles service that is not loading in ArcGIS Pro 3.2.1
Here is the service endpoint:
https://vic.digitaltwin.terria.io/api/v0/data/038d699f-9167-4dbc-9920-cb9b2c24786c/v2/tileset.json
It is a valid 1.0 version 3D Tile service.  According to Esri's public release on the topic,
"With the latest update in ArcGIS Pro 3.2, you can incorporate 3D tiles layers from 3D tiles datasets version 1.x. Your data can be both  local sources and public web services." (Emphasis mine)
Verification of functionality (QGIS add scene connection):
Result in ArcGIS Pro 3.2.1:
What I've tried:
Adding as global scene
Adding as local scene
In local scene, forcing projection by setting both horizontal/vertical scene projections to the layer itself
No errors are offered; however, the service does not render.  Ideally the service should render, or throw an error if it cannot render properly.  Ideas?
Tags (3)
Andrew--Johnson
Hi Eric,
It looks we do not support rendering this 3D tiles dataset because instead of the texture being stored with the dataset it is a reference to an external jpeg file. We are working on supporting this in the next release of ArcGIS Pro 3.3 in late spring/early summer so expect this to work then.
thanks,
Andrew
Andrew--Johnson
Hi Eric,
Where is this supposed to be located? We'll take a look and get back to you.
thanks,
Andrew
EricEagle
Hi Andrew, this service is supposed to load around Melbourne, Australia.  It does seem to zoom to the right extents, it's just that no geometry draws.
Andrew--Johnson
Hi Eric,
thanks,
Andrew
EricEagle
That is very helpful to know, thanks Andrew!
