Using Task Designer with Map Series
725
06-03-2024 10:47 AM
JaronJensen7
I work for a telecommunications company, and I use ArcGIS Pro map series to create our as builts for our service drops. Each drop has its own, unique work order number that contains information for each drop. The data is collected on a web layers that our construction crews fill in using Field Maps. Some of the data they collect are sequentials located on the cable that gives us the total footages of cable and conduit that is placed in the drop.
When I am exporting the as builts I have to verify the sequentails to make sure that the footages all add up. This is a process that I do for each work order on a weekly basis. If there is an error then I have to send it back to construction to fix.
I was looking around and found the 'Tasks' that I think I could use to run this verification for me, so that I save myself a lot of time.
Is it possible to use ' Tasks' with a map series, and have it run the verification for each unique page in the map series?
