Using Dynamic Text in Table Frame for Map Series
1104
05-20-2024 02:27 PM
mmetzcar
Does anyone know if there is a way to use dynamic text in a table frame for a map series?
I have a thematic map series, and I want to add some stats to each map as text. I have a table with the stats of interest and want to show only the rows where the "Network" attribute pages the map's page name. This would allow me to show only the stats that are relevant for each map in the series.
I tried to configure the Table Frame element to use a query to filter. This was the query I tried:
Network = '<dyn type="page" property="name"/>'
That didn't work. Does anyone have ideas about how I can pull data from a table only for the rows in the table where an attribute matches the page name of the map in the series? (In this case the Page Name is the same as the group layer radio button used for the thematic series.)
Thanks for putting on your thinking caps. 🙂
mmetzcar
I reached out to Esri support. My support person verified there was no way to do this using dynamic text and the Table Frame. He's going to look into alternative workflows to accomplish the same end goal.
