Upgrading to Pro Annotation causes many Annos to disappear
3334
10
11-12-2019 01:13 PM
MatthewDriscoll
Using a sql sde database when I upgraded the Annotation many of them are ghosted.  They are still in the attribute table, but they do not show in the map and are not selectable.  I can double click on them in the attribute table and they will zoom to where they are suppose appear but they are not there.  It does seem to work if I export them to a file geodatabase.          .
So much for switching to Pro.
I do have a case opened.    Wanted to see if anyone here have any ideas or have come across this?
ArcMap 10.5.1
Pro 2.4.2
sql server 2016
Workflow:
Reconcile Post Compress
Disconnect Users
Make sure they have a default Annotation Class
Unregister As Versioned
Update Annotation Feature Class
Upgrade Geodatabase
Upgrade Dataset
MatthewDriscoll
It's a bug.  From this and other things I read apparently Pro has a hard time with SQL Server annotation.
https://my.esri.com/#/support/bugs/BUG-000126928
