Updating to ArcGIS Pro 3.0
985
01-26-2023 07:28 AM
DanielleCDobisch
Following an update to 3.0, the software is refusing to open.  I'm seeing the following error:
I have ran through all of the fixes to install the missing frameworks to no avail.
Top 5 Ways to Fix .NET Framework 3.5 Missing in Windows 10 (minitool.com)
DavidSolari
MVP Regular Contributor
DavidSolari
Did you install this version of the .NET runtime specifically?
DanielleCDobisch
Thank you! It worked
DavidSolari
Great! I got this straight from the official docs, I recommend you keep them on hand until you've fully tested your deployment just in case you run into any other issues.
ElwynWilliams
no luck for me, even choosing that specific version, the arcgis installer doesn't recognize the windows desktop framework as installed.
