I have >30 maps to make with ~40 layers in them. The data for the different maps is stored in geodatabases with the same file structure BUT each layer has a unique 12 digit ID at the end of their names. I am trying to update the geodatabase and feature class where the data sit to speed up my map making.
The following code (adapted from https://community.esri.com/t5/python-questions/arcpy-layer-updateconnectionproperties-not-working/td-p/519982) works fine as long as the dataset from the old geodatabase has the same name as the one in the new geodatabase, but as soon as I change the dataset name (with or without a number in it), the script doesn't work. I don't get an error but it just keeps pointing to both the old gdb and the old feature class within it.
How do I fix this?
Any help would be greatly appreciated.
import arcpy, os
import pprint
# .aprx we are using as template
aprx = arcpy.mp.ArcGISProject(r'C:\\temp\\ESRI_aprx_change\\proj1.aprx')
# Look at this especially for how to update (joins)
# https://pro.arcgis.com/en/pro-app/2.8/arcpy/mapping/updatingandfixingdatasources.htm
# make sure I can access the gdb
# https://pro.arcgis.com/en/pro-app/2.8/arcpy/functions/describe-object-properties.htm
##desc = arcpy.Describe(r"C:\\Users\\davisay2\\Desktop\\GEO495_USAFA_F21\\Mouse\\RestorationAreas.gdb")
##print("CatalogPath: " + desc.catalogPath)
##for child in desc.children:
## print("\t%s = %s" % (child.name, child.dataType))
###https://community.esri.com/t5/python-questions/arcpy-layer-updateconnectionproperties-not-working/td-p/519982
# Input parameters are the chosen map within the current project, name of new geodatabase, and name of new feature class
#mapName = arcpy.GetParameterAsText(0)
#newGDB = arcpy.GetParameterAsText(1)
#newfc = arcpy.GetParameter(2)
## code to automate later
#map = aprx.listMaps(mapName)[0]
# Looking in Map1 in that .aprx
map = aprx.listMaps("Map1")[0]
# Looking for the feature class named RestorationAreas
layer = map.listLayers("RestorationAreas")[0]
## https://support.esri.com/en/technical-article/000021613
# Call the connectionProperties dictionary.
pprint.pprint(layer.connectionProperties)
#Specify the current data source (geodatabase) dictionary.
new_conn_prop = layer.connectionProperties
# Point to the new geodatabase base
new_conn_prop['connection_info']['database'] = r'C:\\temp\\ESRI_aprx_change\\RestorationAreasCopy.gdb'
# Point to the name of the new feature class
new_conn_prop['connection_info']['dataset'] = 'RestorationAreasCopy'
##new_conn_prp['connection_info']['workspace_factory'] = 'File Geodatabase'
#new_conn_prop['connection_info']['database'] = newGDB
#new_conn_prop['connection_info']['dataset'] = newfc
layer.updateConnectionProperties(layer.connectionProperties,new_conn_prop)
# output new aprx
aprx.saveACopy(r"C:\\temp\\ESRI_aprx_change\\proj8New.aprx")if line 47 is changed to this the code works:
new_conn_prop['connection_info']['dataset'] = 'RestorationAreas'
