Unusual labelling behaviour in ArcGIS Pro that seems to be related to output resolution
11806
23
11-05-2015 12:19 PM
MervynLotter
MVP Regular Contributor
I just want to share with you some unusual labelling behaviour in ArcGIS Pro. I dont think it is anything that I am doing wrong, but perhaps someone may know the reasons why this is happening or have suggestions for a better work-around? I am hoping this issue may be rectified in future releases as it is really complicating my current workflow.
I have a large A0 map (46 x 33 inches) with a lot of cadastral data that I label. There are probably around 900 features that are labelled on the map. In the map I include a layer of our local municipalities as large single-part polygons. I only want to display one label per municipality and the map output needs to be in TIFF.
Under label class properties I have changed the default settings to Remove duplicate labels as well as ticked Label largest part.
When exporting low resolution (100 dpi) maps, the output map is created correctly and I only have one label per municipality. But when exporting as a high-resolution map (300dpi), the labels for each of the 7 municipalities is repeated several times no matter what setting I use. Therefore the adherence to label settings seems to be resolution dependent for tiff and JPEG images in maps with many features labelled. This problem is not repeated for PDF and I find the PDF map outputs great (but not what I need).
The one work-around I have thought of is to create points and label these, but I have not yet tried this. Other ideas?
KateNewell1
I am having same issue.  Using Arc Pro 2.1.3
KarenLeu1
I am having the same issue with labels duplicating when I export to jpg, and I am only exporting at 96 DPI. The layout size of my map is large, if that makes a difference, at 4' x 9'.
SaidDouai1
Still having the same problem with Arc GIS Pro 2.3
SaidDouai1
I had the same problem before some of my symbols were not showing in the PDF. My problem was that when I export to PDF the Embed fonts was checked but when I unchecked it everything works fine.
 I hope this will help.
Said
