Unexpected Panning in ArcGIS Pro
1869
03-10-2021 11:38 AM
DaniellaSollitt
Hi team,
one of my colleagues have been having an issue, their map is panning to a different place when they click back into Pro from a different application like firefox or OneNote.
Has anyone else been experiencing this or know how to fix this?
Cheers
jcarlson
MVP Alum
YES. My colleagues and I see this issue frequently, most often when using the hotkey Ctrl + Win + Left/Right to move from one desktop to another, but certainly at other times.
While I have not been able to figure out why it's happening, if you just press whichever arrow key the map is panning to, it will stop. Since the panning was a single continuous movement, hitting Previous Extent should bring you right back.
I'll certainly be interested to see if anyone can come up with a permanent solution to this.
- Josh Carlson
Kendall County GIS
ck8256
Similar issue and I unplugged my wireless mouse USB  and plugged back in.   It fixed the problem.   Hope its an easy fix.
DaniellaSollitt
Will try this and see if it works, thanks heaps
DanPatterson
project backstage... navigation... is "panning gestures" toggled on or off?
... sort of retired...
