Unable to Remove Record Only in Default Using Branch Versioning
1029
07-23-2024 11:07 AM
JasminePrater
We have an SDE that is entirely Branch Versioned.  My coworker published the service for our Zoning layer, which is working great.  However, I found a duplicate record with null values in the Default version that is not in the Service.  I am unable to delete it from Default and am unable to create a version from the SDE.  I have tried opening and closing Pro, refreshing the Service, etc. and still can't see the duplicate record in the Service layer.  Can someone please offer advice on how I can remove this record from Default without republishing?
JasminePrater
I was able to resolve the issue by restarting the service for that layer.  I was able to see the null field in the service version I was using and deleted it from there.  Once I reconciled, the record was then removed from Default as intended.
JasminePrater
