Just installed ArcGIS Pro Desktop version 3.5 and finding the learning curve extremely steep. I've been searching thru the online documents and videos, however, they either leave out critical details or are for older versions that don't match the screens I see in 3.5. I created a new map project and placed 3 locations on the map using WG 84 lat/long coordinates. I want to add labels to each of the locations. My locations are in a feature layer called Locations. According to what I've found here and elsewhere online, I should click the layer and then I should see a Feature Layer tab set with a Labeling tab but I'm not seeing that anywhere in the ribbon. I'm sure I've missed something or skipped a step somewhere but I'm not able to determine what it is. Any suggestions?
Thank you.
