Trying to update Pro to 3.3 but being kicked out because of a "WebView2" error
2111
05-09-2024 04:41 PM
Royce_Simpson
According to my system, I already have webview2 installed and .net 8.0.4 Desktop Runtime.   When I try to upgrade my Pro installation from 3.2.2 to 3.3, I get an error, "ArcGIS Pro requires Microsoft Edge WebView2 Runtime(x64). ... ... ...".
I'm not sure what else I can do to get this to work.  I've tried "repairing" my WebView2 install and my .net 8 install to no avail.
x (x)
Royce_Simpson
Not sure what the issue was with updating Pro through the built-in updater within the software, but when I downloaded the stand-alone 3.3 install exe, it installed fine.
x (x)
DanPatterson
MVP Esteemed Contributor
I would suggest Tech Support, especially if you are using a machine in an organization and not a standalone machine.
There are a few articles on this WebView2, which I haven't heard about until today, but perhaps they will ring a bell for you
Problem: ArcGIS Pro, AllSource, Drone2Map and RealityStudio Require the Microsoft Edge Web (esri.com...
BUG-000153158 for ArcGIS Pro (esri.com)
Again, Tech Support would be best
... sort of retired...
Royce_Simpson
x (x)
ChelseaRozek
MVP Regular Contributor
Hopefully this can help someone else: I was having the same issue, but running the webview2 installer again as an administrator got it to work. Per the documentation: "A per-machine installation (the default) of ArcGIS Pro requires a per-machine installation of WebView2 Runtime. To do this, right-click the WebView2 installer and click Run as administrator."
