Tool For homogeneous zones
1217
09-08-2021 07:53 AM
alejocasf
Hi Community.
I would like to know if someone can help me with this.
I have 3 different layers, all polygons.
- Roads
 - Landuse
- Drainages
These polygons has tables with data.
I want the software to look for areas where there are similarities between the three layers based on attributes inside the datatable. For example:
An area will have landuse "Residential" with Drainages "5 meters width" and with road type "highway"
Other area may have landuse "recreational" with drainages " 10 meters width" and road type "secondary road"
Words between "" is data comming from the attribute table.
The importan thing is I want the software look for this areas comming from the attribute table data, then being represented as a common area, or homogeneous zone. Or areas the same info within.
  • Thanks for your help.
KoryKramer
Esri Community Moderator
Have you looked at Similarity Search? https://pro.arcgis.com/en/pro-app/latest/tool-reference/spatial-statistics/similarity-search.htm
EDIT: I guess we would also need to know what product you're working in; i.e. ArcGIS Pro, ArcGIS Online, ArcMap, etc.
alejocasf
Hi. I'm working with ArcGIS Pro.
JayantaPoddar
MVP Alum
Could do a Union of all the three layers, followed by Dissolve using the three fields of the Union layer?
Think Location
