Time enabled Raster Mosaic in ArcGIS pro not working in Javascript API
568
01-26-2023 07:34 AM
RuthCostley1
Hello! I have created a number of Javascript API web apps with the time slider widget to show time from a Raster Mosaic Dataset. (See TimeSliderExample ). The original services were created using ArcGIS server 10.6 with the ArcMap service runtime. We recently updated the services to the ArcGIS Server 10.9 with the ArcGIS Pro service runtime. I recreated the map service exactly as before in the time settings, but now the Javascript API web apps don't work. (See the attached script). I have noticed that if I remove the setting mode= "instant" so that the default mode="time-window" is used it works, but it isn't the look we want with the exact stops.  If you have any suggestions, please help.
