Synced Web Map from Portal not Updating
1182
06-30-2020 08:32 AM
KamillePreto
Hello!
I have a synced Web Map from Portal (Enterprise) that I always update in Pro for ease of use and the edits automatically update on the Portal end on-the-fly.
However, I just made an update and it did not automatically update like it always does. I have refreshed and done all of the basic checks.
Any ideas why it suddenly isn't syncing?
Thanks.
Tags (3)
JonahLay
Hi Kamille,
If you are trying to update the map in your ArcGIS Pro project with the current version of the web map on the portal, did you follow the steps outlined in this topic? Add maps and scenes to a project—ArcGIS Pro | Documentation
If you are trying to update your existing web map with the map in ArcGIS Pro, this is a functunality that will appear in an upcoming ArcGIS Pro release.
Best,
Jonah
CatherineHudson1
Were you able to solve this problem? I just updated a dataset by appending the information to the table of an already published map through portal. When I reload through the portal the changes look like they are there. However when I open the map through my contents page the update has not been made.
