Symbology Not Showing
16462
11
02-09-2018 08:21 AM
ConnorKeef
I'm having a problem with ArcGIS Pro not showing symbology for a layer I'm trying to display.  I have the Census Zip Code tabulation shapefile, which I have joined to a .csv that shows constituents in each Zip Code.  The fields have properly joined and the Symbology is showing values for the breaks.  However, it is not showing them on the map.  I've attached a screenshot of my desktop.  Problems Displaying Symbology
MichaelVolz
Esteemed Contributor
What version of Pro are you working with?
Do you have the ability to see if the same layer setup would work in whatever ArcMap version you have access to?
MarkBockenhauer
If you use the single symbol symbology do the polygons display correctly?
ConnorKeef
ConnorKeef
It seems so.  The fact that some of the values are <Null> is not a problem, is it?
Robert_LeClair
Esri Notable Contributor
Can you provide a sample of the data that I use to troubleshoot in my ArcGIS Pro?
ConnorKeef
Try this... I saved the layer as a layer file, but I'm not sure if the Joins to the .csv work or not.
https://files.fm/u/5vrgydku
DanPatterson_Retired
If you make the join permanent so that you aren't dealing with a joined csv file anymore... does the symbology show then?
Robert_LeClair
The site seems to be down - I'll try again early next week.  Thx!
mrmark
Robert.
Here is a link to a zip file with the project I used in the video below. It has a project that has a geodatabase in it with two data sets from the Esri Data & Maps for ArcGIS 2017: cities_dtl and states. It also has a CSV that has median rent prices by state and for many cities across the country. The CSV field that joins to either state names or cities names is "Location"
JoinTesting.zip - Box
** At least there is a workaround other than creating a new data layer with the joined data included. The larger problem I run into is that as soon as you join tables changing symbology or even redrawing the map goes from blink of an eye quick to over 60 seconds. If changing symbology it is usually 60 seconds to determine new class breaks, then another 60 before it re-draws -- IF it redraws. With the lack of an Apply button and every single symbology change taking over a minute to do anything it is very hard to keep using Pro.
Here's a video demonstrating: JoinscausemajorslowdowninPro.mov - Box
Both of these were on a Citrix XenApp server with two NVIDIA M60 GRID cards (8Q profile = 16GB vGPU), 8-core XEON & 64GB RAM.
A man's feet should be planted in his country, but his eyes should survey the world. - G. Santayana
