Symbol problem in share for web map, double or triple dashes - road symbology
796
02-02-2022 11:17 AM
MirianIsabelSay
Good evening! when giving share to web map, the road symbol that has double dash, presents the error: Layers symbol will be downgraded. Can't use double or triple dashes?
Thanks.
Mirian
Robert_LeClair
Esri Notable Contributor
This is correct in the sense that symbols using multilayer symbols are not support symbologies on the web feature layer.  the symbol is then downgraded to a simple symbol that is supported in the web feature layer.  Only options are to accept the downgraded symbology when the layer is published or change the layer's symbology in ArcGIS Pro before publishing.
jdruding
Is this a possible enhancement in future? I was a little surprised to find  that even a railroad track symbol wasn’t supported on the web?
Robert_LeClair
There is an enhancement request - ENH-000087498 - that is marked as "Under Consideration" so that bodes well.  Hopefully a  future release introduces this capability.
