Smooth the boundary of a buffer into transparency
1547
04-19-2024 02:26 AM
GIS_User_1996
Hello!
I was wondering if there is a possibility to smooth the boundaries of buffers around points that in the end NO boundary of the buffer is visible. The transparency of the buffer should increase by moving away from the central point.
Here an example:
What I am searching for is making the boundary of the buffer (red) completely invisible, so the buffer is increasing in transparency. In the middle of the buffer (point) should be the lowest transparency and around the boundary the transparency should strongly increase.
I am not sure if this visualization is possible since a polygon is limited by a boundary.
If anyone has any answers I would greatly appreciate it! 🙂 Thanks in advance!
DanPatterson
symbology : buffered gradient
properties: outline width 0buff.pngbuff2.png
obviously you would pick a less obvious patch color and you can mess around with the pattern
... sort of retired...
AlfredBaldenweck
MVP Regular Contributor
One issue to watch out for is that the Buffer Gradient doesn't support Continuous option, which is annoying. You can get around it by setting your number of intervals higher, but that slows performance.
BobBooth1
I was also going to suggest a gradient fill (and no polygon border color).
https://www.youtube.com/watch?v=LXB9GQCak_A
How do you choose whether to use a light or dark coastal halo effect for your water features? Generally, I like to use a darker color for the coastal halo of a light basemap and a lighter color for dark basemaps. But this is more of a...guideline. Check out some other social channels where I share
BobBooth1
Here's how to make a glassy sassy classy extent indicator for your overview map. Check out some other social channels where I share how-to's and updates on random map adventures: http://adventuresinmapping.com https://www.esri.com/arcgis-blog/author/j_nelson/ https://twitter.com/John_M_Nelson ...
You want some of an image layer's pixels but not all of them, right! You don't have to treat them all the same, you can feather in transparency at any point along your color gradient...and effectively erase bits of the image. You could do all sorts of classification and raster math...but this is a
