Show points when count of attribute is greater than n
887
02-15-2024 11:40 AM
AndrewIngall2
Hello
I have a load of point data which i have filtered down to just show business properties, which works fine.  I am now trying to show only those properties where the number of premises on a street is greater than n.
I know I am missing something simple here, but how do i show only those records when the count of the street is greater than or equal to 'n'?
street 1 ID - count 5 do not show
street 2 ID - count 10 show
Thanks
Ed_
by MVP Regular Contributor
One way could be Arcade, now I am not an Arcade expert but this, Symbology, Arcade and Group By  might help.
Another option could to be use the `Summarize` tool to get a `count` column for `n`, then join (Join Field tool) that `count` column from the summary statistics table to your point data. After the join, run a query where `count` is `5` do not show and show. Hope this helps, cheers and good luck 🙂
Question | Analyze | Visualize
Bud
Esteemed Contributor
Can you explain why a definition query won’t work?
Can you provide a screenshot of your data including the attribute table?
