Sharing my Scene using share as Scene failing to get published
687
11-08-2023 02:48 AM
AbhyanshuGupta
I have created a scene in ArcGIS Pro which stores indoor information of a building, i am trying to publish this scene onto my enterprise account using Share As WebScene tool but it is giving a failed to publish error and the error log is as following:-
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:01Status: InProgressStatusMessage: Successfully wrote sharing info file
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:01Status: InProgressStatusMessage: Creating thumbnail from map
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:01Status: PendingStatusMessage: Sharing process started
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:01Status: InProgressStatusMessage: Sharing process started
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:02Status: InProgressStatusMessage: Reading thumbnail from file
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:02Status: InProgressStatusMessage: Sharing process started
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:03Status: InProgressStatusMessage: Extracting all manifests from the configuration of the web map/scene
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:03Status: InProgressStatusMessage: Publishing individual web layers
IFloorPlan_WebScene_WSL1 20 LocalWebScene ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ abhyanshu.gupta 2023-11-08 15:54:03 Status: InProgress StatusMessage: Loading manifest
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:03Status: InProgressStatusMessage: Reading thumbnail from file
IFloorPlan_WebScene_WSL1 20 LocalWebScene ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ abhyanshu.gupta 2023-11-08 15:54:03 Status: InProgress StatusMessage: Publishing process started
IFloorPlan_WebScene_WSL1 20 LocalWebScene ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ abhyanshu.gupta 2023-11-08 15:54:03 Status: InProgress StatusMessage: Consolidating data and staging web layer
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:08Status: InProgressStatusMessage: Using ArcGIS Version 13.0 for staging (Source for version: GP Staging Parameters)
IFloorPlan_WebScene_WSL1 20 LocalWebScene ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ abhyanshu.gupta 2023-11-08 15:54:08 Status: InProgress StatusMessage: Stage Tool initialized
IFloorPlan_WebScene_WSL1 20 LocalWebScene ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ abhyanshu.gupta 2023-11-08 15:54:08 Status: InProgress StatusMessage: Preparing maps and layers for processing
IFloorPlan_WebScene_WSL1 20 LocalWebScene ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ abhyanshu.gupta 2023-11-08 15:54:08 Status: InProgress StatusMessage: Consolidate data
IFloorPlan_WebScene_WSL1 20 LocalWebScene ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ abhyanshu.gupta 2023-11-08 15:54:08 Status: InProgress StatusMessage: Staging feature service
IFloorPlan_WebScene_WSL1 20 LocalWebScene ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ abhyanshu.gupta 2023-11-08 15:54:09 Status: InProgress StatusMessage: Compressing package into SD file
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:09Status: InProgressStatusMessage: Staging successful
IFloorPlan_WebScene_WSL1 20 LocalWebScene ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ abhyanshu.gupta 2023-11-08 15:54:09 Status: InProgress StatusMessage: Uploading service definition
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:10Status: InProgressStatusMessage: Publishing tool initialized
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:10Status: InProgressStatusMessage: Publishing web layer (AGO)
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:52Status: InProgressStatusMessage: Sharing web layer
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:54:52Status: InProgressStatusMessage: Publishing tool succeeded
IFloorPlan_WebScene_WSL1 20 LocalWebScene ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ abhyanshu.gupta 2023-11-08 15:54:54 Status: InProgress StatusMessage: Creating scene service started
IFloorPlan_WebScene_WSL1 20 LocalWebScene ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ abhyanshu.gupta 2023-11-08 15:54:56 Status: Failed ErrorMessage: Failed to publish scene service
IFloorPlan_WebScene_WSL1 20 LocalWebScene ArcGIS Enterprise https://dev02351-001.nagarro.local:7443/arcgis/ abhyanshu.gupta 2023-11-08 15:54:58 Status: Failed ErrorMessage: Failed to publish web layer
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:55:00Status: FailedErrorMessage: Failed to publish web layer IFloorPlan_WebScene_WSL1.
IFloorPlan_WebScene20LocalWebSceneArcGIS Enterprisehttps://dev02351-001.nagarro.local:7443/arcgis/abhyanshu.gupta2023-11-08 15:55:02Status: FailedErrorMessage: Failed to publish one or more web layers
Can anyone help and tell me how can I resolve this issue?
Regards
