Share branch versioning to AGS
12193
13
03-11-2021 05:17 AM
Labels (2)
Antonio_Dang
Hi there!
Im trying to share a feature service with branch versioning to AGS but cant enable the version management:
Does share branch versioning only with portal and enterprise and not AGS standalone?
thx for any advice!
ccharping_patrickco
Per ESRI documentation at https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/overview-of-versioning-in-a... you need at least a Standard or Advanced license.
ClaudioRuschel
I understand that these licenses are needed to manage the geodatabase content. But, considering that one wants to edit a Feature Service, I think it is required only an "Editor" user from ArcGIS Portal if it is available through a Web GIS application. If you want to use ArcGIS Pro to edit this service, beyond the Portal´s "Editor" role, is it also needed an Standard or Advancee license?
Antonio_Dang
Hi there, sry for late reply.
But you workaround works fine 🙂
Strange that we have to found a workaround like this, hope this stil work in the next ags update 🤔
RichRuh
A group of us here at Esri came across this post while working on another issue. Branch versioning is built to work with Portal-federated feature services, and not AGS standalone.
I'm glad you were able to find a work-around, but while we won't do anything to intentionally block this scenario, it's also not supported and might not work in a future release.
