Setting the number of decimal places in a feature class field using python
1099
08-15-2023 08:04 AM
YS2388
I need to create a bunch of field with different number of decimal places. I'm using the "Add Field" tool to set the scale but it is never respected. These fields are in a gdb feature class. I'm using float or double. It is possible to set the number format and decimal places manually in Pro but this is not feasible in my case.
Thank you for the help.
DanPatterson
MVP Esteemed Contributor
From the help...
Add Field (Data Management)—ArcGIS Pro | Documentation
Note:
Field precision and scale are not supported in a file geodatabase feature class or table. If you enter a value for precision or scale, it will be ignored.
applies to the multiple fields tool as well
... sort of retired...
YS2388
Hi Dan,
Yes I read that as well and thought someone else might have a different idea. It is unfortunate that this feature is being retired...
