Set the color of a point using an Arcade When() statement
483
01-31-2025 11:55 AM
MPach
I'd like to know if there is a way to set the color of feature layer symbology using an Arcade statement.
What I'd ideally like to do is something like this, but I can't seem to find the correct syntax. The part in question is the if the color feature can be set.
When( $feature.Device_Due_Date > DateOnly(), $feature.color = #000000....
I'm not certain if color is a property of the $feature that can be accessed, but I think it recall in ArcGIS Online Maps that it's a property that can be set using a hex color as shown above.
Thank you
ToddW_stl
UPDATE: sorry, I see this is in the ArcGIS Pro section, not ArcGIS Dashboards.  Let me see what else I can find if the info below doesn't help.
for ArcGIS Dashboards - Yes, you can.  Upon a quick skim, this post by my colleague, @JenniferAcunto , describes how to do this.
Dashboards That Pop: Advanced Formatting Troubleshooting
MPach
Thanks for the reply. I think I should have specified that I was trying to do this in ArcGIS Pro. I'm not certain if the syntax is the same as doing this in one of the online applications.
ToddW_stl
on the surface, it appears to be possible, but I have not tried it (yet).  these may help you figure it out!
