Set Map and Database Spatial References for Projects/Templates
1289
01-06-2020 11:31 AM
SaraCourter
My team and I create maps for airports throughout the United States. All of the projects will have the same databases, same features, same layouts, and so on. We generally work in State Plane Coordinates (and use NAVD88 height ft US), so as the airport location varies so does the projected state plane.
Our question is, when we create a new project and select a template that we want, is there an easy method for us to get it in the desired projection?
Asrujit_SenGupta
You can probably set the Default Spatial Reference as below:
