When using "Unclassed Colors" as the primary symbology of a raster layer in ArcGIS Pro, is it possible to set an exact value for the midpoint? It appears as if you can only specify the min and max values:
I want to achieve a divergent color ramp that centers on 0. The best I can do is play around with the colors of the actual color ramp, but this is not exactly scientific and does not achieve the precision I am after.
And I do not with to use a classifed symbology, which I realize does allow you to specify specific breakpoints.
