Service Area Analysis - different results in ArcMap vs ArcPro ?
6607
14
04-12-2019 08:47 AM
SonaSunny
I am trying to create a 2.5 mile service area around all the fire stations with Ladder Trucks. I ran the analysis in ArcMap and in Pro, using the same settings. But the results don't match. The Line generated matches but not the polygons. For example , the screen shot below shows the service area polygons and Line created in Pro (green) and ArcMap(blue) . There are no line generated in the area highlighted in the middle, but the ArcGIS Pro generated service area polygon covers that area. Also, the service area polygon for station 45 looks so different in Pro vs ArcMap even though the line generated are the same.-
ArcPro
ArcMap
ArcMap
Any idea what could be causing this ? Is ArcGIS Pro more accurate than ArcMap?
JaySandhu
What settings were used in ArcMap and Pro? Default? Do note that by default, ArcGIS Pro does Standard Precision and not Generalized. In ArcMap, the default setting is Generalized.
DylanHarwell
I've compared both and the polygons still were slightly different. Not as radically different as in this example though.
SonaSunny
The above example is - Generalized in ArcMap and High Precision in ArcPro.  I tried the std precision in Pro with the generalized in ArcMap and that also was different .
SonaSunny
The travel Mode - i changed to Trucking in Pro. Didn't see anything for that in ArcMap.
Ryan_ESRICommunity
Hello, Like the others, I'm wondering if there's been any update on this thread? I've searched through the settings in Pro to reproduce the polygon output from AcrMap but I can't seem to locate a "generalized" setting. The only options are Standard and  High precision? Accordingly, is it even possible to emulate the results or is this just a function of different solver being employed in Pro? Thanks!
