I created a boundary shapefile using the same UTM coordinates in both GeoPandas and ArcGIS Pro. However, after projecting both shapefiles, I noticed that the boundaries' extent and coordinate placement differ. They are not aligning correctly as expected.Typically, I work with GeoPandas, but there are instances when I require ArcGIS Pro. What steps should I take to ensure that my data aligns properly in ArcGIS Pro?
