RuntimeError: The Product License has not been initialized.
1135
05-07-2024 02:29 AM
jasminearora
Getting the below error while running the python script via Azure Devops pipeline as not getting while running manually.
Using arcgis pro with concurrent use license
using arcpy to update connection properties within an ArcGIS project file (*.aprx). This script is updating the connection properties for a Geodatabase connection within the project and then saving a copy of the updated project file.
Python Script:
import arcpy
aprx = arcpy.mp.ArcGISProject(r'\\.../../../C.aprx')
aprx.updateConnectionProperties(r'\\ESRI@g.sde', r'\\ESRI@g1.sde')
aprx.saveACopy(r"\\B.aprx")
Error Encountered:
import arcpy
File "F:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py", line 77, in <module>
from arcpy.geoprocessing import gp
File "F:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\__init__.py", line 14, in <module>
from ._base import *
File "F:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 14, in <module>
import arcgisscripting
File "F:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgisscripting\__init__.py", line 131, in <module>
from ._arcgisscripting import *
##[error]Cmd.exe exited with code '1'.
MathiasKPoulsen
In this other thread https://community.esri.com/t5/arcgis-pro-questions/arcgis-pro-runtime-error-the-product-license-has/... the solution was to use a single use license.
