Revit 2024 Support in ArcGIS Pro
5410
7
12-20-2023 07:28 AM
BryanOReilly
Hello,
Based on the documentation I found below the current version of Pro only supports up to Revit 2023.
 https://pro.arcgis.com/en/pro-app/latest/help/data/revit/supported-bim-geometry.htm
Are there any plans in the upcoming updates to extend support for Revit 2024? If so is there a roadmap/ timeline for when that will be updated?
Thank you!
2 Solutions
Andrew--Johnson
Hi Bryan,
It is currently planned for the ArcGIS Pro 3.3 release to support Revit 2024. We are currently targeting the next release to be late spring/early summer.
thanks,
Andrew
MichaelDavidsonPM
Hi @BryanOReilly  and @MarkusWall1  and others,
I'm happy to share that the Nov. 2024 release of ArcGIS Pro 3.4 includes support for Revit 2020-2025:
https://www.esri.com/arcgis-blog/products/arcgis-pro/announcements/whats-new-for-cad-and-bim-in-the-...
DanPatterson
MVP Esteemed Contributor
you can get an idea based on previous timelines
Solved: Revit 2023 support in ArcGIS Pro - Esri Community
but @Andrew--Johnson may have a more definitive answer
... sort of retired...
Andrew--Johnson
Hi Bryan,
thanks,
Andrew
kdramey60
Hi There. This is Kevin with the City of Portland Environmental Services. I was reviewing this thread hoping to resolve my issue with ArcGIS Pro reading my my Revit 2024 BIM models. I am currently using ArcGIS Pro 3.3 and when adding the Revit file I get the following message:
Any suggestions?
Kevin ([email protected])
TrondRolland1
This is indeed a problem, as Revit cannot export to anything earlier than 2024 ver by now. So this means that each year there will be half a year of not being able to import new rvt files to AGpro? How about making a patch for this issue? It is a real problem
MarkusWall1
will Revit 2025 be supported by ArcGIS Pro 3.4?
@TrondRolland1 a possible solution is to export an IFC file from Revit as work around for this half year.
emreaktas1
hi @MarkusWall1
Can you pass the Revit 2025 fee with Arcgis? I have the same problem.
MichaelDavidsonPM
