Reclassify tool (convert NODATA to value) works in ArcMap / fails in ArcGIS Pro
6213
11
01-22-2021 09:58 AM
MichaelRehberg1
Good morning,
Has anyone else encountered this problem?
I've already found a workaround for this issue, but it's less than ideal.
Using the reclassify tool (Spatial Analyst), I was reclassing a raster that created from a polygon feature class.
The raster had a value in each cell within the polygon, and a NODATA everywhere else.
Using the reclass tool in ArcMap, to change these NODATA cells to have a real value, worked fine.
Using the reclass tool in ArcGIS Pro, however, using the same feature classes, failed when I did this, with this error:
ERROR 999999: Something unexpected caused the tool to fail. Contact Esri Technical Support (http://esriurl.com/support) to Report a Bug, and refer to the error help for potential solutions or workarounds. Failed to execute (Reclassify)
JamesTenbrink
I don't know what InVEST is. 😀
Can somebody else comment? Or maybe that should be a separate post?
-jt
als21
Was there ever a solution for this. I have a model that requires one input to reclassify NoData to 10, the first time I ran the model the output was fine. Now that model and all other attempts as getting my NoData to value 10 fail. There is No message, the reclassify just does not perform the NoData =10 in the reclassify. It also provides the output file with a different NoData value the original file, which the environments tab states NoData set to NONE should keep the original NoData value?  ArcPro 3.1
