Raster values in legend not honouring DRA
2325
07-30-2021 05:45 AM
MattHowe
I'm using a single band raster in a new layout and have activated DRA so the stretch only uses the data within the view extent. In the legend it looks like the values aren't adjusted as per the DRA. Is this a bug or is there a way to adjust the values of the raster in the legend automatically to reflect the cell values shown in the current view only?
Tags (3)
TomBole
Hi Howeitzer,
It is possible that you are running into a known issue -
BUG-000112368: Raster statistics fail to update dynamically with display extent when using stretched symbology imagery and dynamic range adjustment (DRA) in ArcGIS Pro.
To confirm this please contact support. They can confirm that this is the same issue or help enter a new issue if your scenario is different. They can be contacted at https://support.esri.com/en/contact-tech-support.
Tom
TomBole
Hi Howeitzer,
Tom
MattHowe
Thanks Tom I'll report the issue via the link. As a quick workaround I clipped the raster using raster functions.
David_Brooks
MVP Regular Contributor
@MattHowe it looks like this one has been promoted to "In the Product Plan". So hopefully we'll see an update in the next release or two
David
..Maps with no limits..
JamieDodd
It's my understanding that this issue was rectified sometime in 2023. Is anyone still having this issue now, in 2024?
CarolineThomson15
I'm still having this issue unfortunately even though Pro is all up to date
