Raster stretched color symbology becomes one color at export
1820
02-21-2024 09:16 AM
Anne-MarieDubois
Hello everyone,
I'm trying to export a layout displaying a raster with a custom stretch color ramp (based on custom statistics and modified min/max). Although everything is fine when viewing in Pro (see exhibit A below)
... whenever I try to export it becomes only one color (see exhibit B)???
I have rebooted Pro.
I have upload the raster again and imported the symbo.
I have tried exporting to a different format.
I have changed the color ramp.
Without results.
Then, I figured maybe it's the customizing it self. Turns out, if I uncheck the "modify min/max values" box it's working.
But I need those values to be different in order to use the same symbology for multiple rasters that don't have the same value range.
Anyone has a fix for this?
Kind regards,
Anne-MarieDubois
OK, turns out I can answer that myself. If you change the min/max in the statistics window and leave the modify min/max unchecked, it's working.
Anne-MarieDubois
