Randomly logged off of portal Error 002199
511
12-06-2022 08:21 AM
BillyBuerger
I'm running some long running processing to update all subnetworks.  I had it up in the background and noticed it was failing stating...
ERROR 002119: Must be connected and signed into the portal.
This was after running for a few hours out of the expected 24hr+.  I had to cancel, log onto portal again and then restart the process.  I've seen this before.  It seems that every so often, you randomly get kicked out of your portal connection.  Is there a reason for this?  Is there  a timeout or settting for how long you are allowed to be logged in?  If so, it would be helpful if it could warn you and let you extend or re-login before getting disconnected.
This is running on a test/staging system where I have Server/Portal/Datastore and Pro all running on the same system.  In case that has any impact on anything.
