I have a problem on Enterprise Geodatabase PostgreSQL 9.4 when I use some geoprocessing tools when select "Feature Class Location" is veryyy slow to select feature dataset, around 2 hours to select.
I clear metadata history as some people tell but nothing. My server is windows 2016 on Azure.
When I select a tinny feature dataset is ok, but when I choose a feature dataset with 10 huge feature classes, is toooo slow. I don't know what I do to solve this problem. any help ?
Note that, when I use pgadmin to select data is everything ok, using ArcGIS PRO ou ArcCatalog no. very slow.
What release of ArcGIS Pro are you using? At ArcGIS 2.9, the following versions are supported - PostgreSQL 13.3 (64-bit), 12.7 (64-bit), 11.12 (64-bit) and 10.17 (64-bit). 9.4 is an old release of PostgreSQL. A couple things to try - have any database maintenance GP tools been run on the feature classes? If not, I would run Analyze, Analyze Datasets, Rebuild Indexes and if you're working with versioned data, the Compress GP tool. All these tools will optimize queries, selections and such.
