Publish model results to Portal from ArcGIS Pro
1747
08-09-2016 08:55 AM
JesseOsborne1
In ArcGIS Pro, I am trying to build out a model using modelbuilder that will perform some geoprocessing tasks and then publish (share as a web-layer) the results to my organization's Portal. Since this model will be run on a periodic basis, I will need the results to Overwrite Web Layer.
However, I cannot find the geoprocessing tool for publishing data as a web-layer in modelbuilder. What is this tool called? Am I going about this wrong?
DanPatterson_Retired
never used... but there is a publishing toolset in the server section An overview of the Server toolbox—Help | ArcGIS for Desktop
