I seem to be unable to publish a hosted feature service (share as web layer) and correctly include my related data tables. This seems to be a new issue as of the 2.0 release.
BUG-000094431
When publishing selected layers in a map, include tables only if they are related.
I think that what you're seeing is a difference in sharing only a selected layer and or the map and all of its layers as a web layer.
See this: Web feature layer—ArcGIS Pro | ArcGIS Desktop
If you use the first option from the Share tab > Share As group > Publish Web Layer, are the related tables included in the published web layer? I tested quickly and that option included a related table, while just right-clicking the individual layer in the Contents Pane > Share as web layer did not.
I have the same problem. I am trying to publish a feature layer with its related table to our organization sandbox (enterprise portal) using the 'Publish Web Layer' option in ARCGIS Pro 2.4, but the relationship is not working in the portal. Note that I tried all above suggested solutions (e.g. publishing with/without a relationship class) and not of them worked. I would be pleased if you could give me a solution for this problem. I have a project deadline to meet and this issue has been delaying my project for weeks now.
Thank you,
Babak
My organization is finding that we are unable to publish layers with relationship classes to our Portal hosted data store. We are able to publish the same data to our Portal and to our ArcGIS Online. We have tried using both ArcGIS Pro 2.4.1 and ArcMap 10.7.1.
The log evidence of the problem begin with SwizzleService failing, and then a host of errors, ending in Error Code 001369: Failure to create the service.
I'm curious why Portal's hosted data store is unable to handle the service, and yet ArcGIS Portal and ArcGIS Online can handle it just fine... Is this due to the nature of Portal's hosted data store compared to Portal and Online?
Thanks,Emma
From the Share ribbon (Publish web layer). In the Share Map As A Web Layer dialog, on the Content tab, only the feature class shows up, not the table. Not sure if the table should be displaying here?
How are you sharing the layer? By right-clicking the layer in the Contents Pane, or from the Share ribbon?
Trying this today in Pro 2.2.4 and the related table does not get created in AGOL. Adding the same data (feature class with related table from a file geodatabase) to ArcMap and I can successfully publish the hosted feature layer with the related table.
I have a client with the same problem loading the feature in ArcGIS PRO
is empty, (I have marked the option mentioned above)
I try to exporter as a feature to feature but an error
http://pro.arcgis.com/en/pro-app/tool-reference/tool-errors-and-warnings/001001-010000/tool-errors-and-warnings-00101-00125-000117.htm
Then I load the service in ArcMAP and I see it without problems but when I try to republish there are 2 serious errors,
Error Code 00004 http://server.arcgis.com/en/server/latest/publish-services/linux/00004-layer-s-data-source-is-not-supported.htmError Code 00033 http://desktop.arcgis.com/en/arcmap/10.3/map/publish-map-services/00033-esrimapserverprepareerrorunsupporteddatasourcestandalonetable.htm
I think it's an exploding problem d ela map extension
regards
Fran
Chad, do you have the Allow assignment of unique numeric IDs for sharing web layers checked on or off in Pro? How is that set in ArcMap?
If necessary, would you be able to share your data for us to work with? We can do that off this thread if needed.
Cheers
Similar problems here, I was able to publish the "Web Layer" with a related table and attachments using Pro 2.0.1 following the Share a Web Feature layer instructions. The fun part is the service publishes to a hosted feature in AGOL, but when I open the map my feature class is empty along with the related table (Zero records for both). If I go back into Desktop and publish the same service from my FGDB source everything works fine.
Max, I'm glad that we were able to help figure out what was happening. Can you do me a favor and revisit the idea that was logged https://community.esri.com/ideas/13902 and rework the title and description to reflect how you think these options can be clarified in the software? This will help others who are experiencing this behavior find the issue on the Ideas site and up vote it.
Thank you.
Kory thank you for that tip. This does indeed seem to be the issue that I was running across. I would note that this is not very intuitive and given that the options are named/labeled the same, and utilize the same symbol there does not appear to be an easily distinguishable difference between the two methods.
Perhaps clarifying the differences between these methods in the documentation would be beneficial?
my layer is already in arcgis online (and includes the related table) what we want is to download it from ArcGIS Pro.
When downloading as FGDB does not maintain related tables
I have a problem to export a feature hosted in ArcGIS Onlien with related tables and attachments
When exporting does not maintain related tables in arcgis pRO
Watch video https://www.screencast.com/t/jJ8RakaY2
I'm having the same issue. Publishing the same feature class w/ relationship classes works fine for me in ArcMap, but not in Pro.
I am also facing this issue. AAwady-esristaff Any Idea what is going on here!
Hmm. I second this one. Overwriting a feature service with related tables, and carrying those relationships through to ArcGIS Online is not working for me.
Signed in members can post, follow updates, and more. New here? Register a free account.
