Problems with authorization ArcGIS Pro Personal Use. Please help
23481
35
03-15-2017 05:30 AM
SashaLeyberyuk
How authorize ArcGIS Pro 1.3 personal use, the site My ESRI under no such authorization functions (although ArcGIS Desktop 10.4 is such an opportunity, and it works fine). How can I authorize ArcGIS pro through ArcGIS Online?
JayantaPoddar
MVP Alum
You need to login to your ArcGIS Online named user account.
Then, configure the ArcGIS Pro license to your named user.
Follow the steps in Manage Licenses - ArcGIS Online
Think Location
SashaLeyberyuk
Many thanks for the answer. But I can not find a tab or link to license or right to access ArcGis Pro at My ESRi, although the license file to the ArcGIS desktop  10.2 - 10.5 and I formed using such operation for ArcGIS Pro I can not do. How to solve this problem?
JayantaPoddar
MVP Alum
You won't get it in My Esri. Login to http://www.arcgis.com. Then proceed with the instructions.
Think Location
SashaLeyberyuk
Grateful for your advice. Now I understand, but the problem is that the tab is missing after authorization. What to do in this case? When purchasing a license, I did not get a link to additional registration for ArcGIS Online. You may need to contact somewhere in obtaining such rights?
JayantaPoddar
MVP Alum
I was expecting to see a "My Organization" link on top. This looks more like a public account.
It would be wise to raise a support ticket with Esri Tech Support, and let them help you with the issue.
Think Location
Dhowal
by Esri Contributor
You need to sign in to your organisations ArcGIS Online account . Do you know the url ? It will be "abc".maps.arcgis.com where abc is the name you chose while setting it up.
JayantaPoddar
MVP Alum
Even if one logs in to www.arcgis.com with one's organizational account username, the site will get redirected to one's organizational account.
But you are right, the final URL of the website should look like https://<ShortOrganizationName>.maps.arcgis.com .
Think Location
SashaLeyberyuk
Thank you for your detailed explanation. I registered as a result did not receive such access. How to apply for support on this issue?
JayantaPoddar
MVP Alum
Write an email to Support@esri.com
Also mention your customer ID in the mail.
Think Location
