Problem creating TPK from orthophoto .tif with ETRS89 → WGS84 datum
389
10-15-2025 02:26 AM
Domine86
Hi everyone,
I'm trying to create a Tile Package (.tpk) file from a .tif raster, which is a three-band, 8-bit orthophoto with an ETRS1989 map datum.
I set the Map scene to WGS1984 and then exported the TPK, but I can't import the result into ArcGIS Earth.
Is there a special setting for creating a TPK from a raster with a datum other than WGS84 without losing compatibility?
Could you explain simply, as I'm a novice and have only been using ARCGIS for a few days.
Thanks in advance for any suggestions!
Hi everyone,
With ArcGIS Pro 10, I'm trying to create a Tile Package (.tpk) file from a .tif raster, which is a three-band, 8-bit orthophoto, with an ETRS1989 map datum.
Tags (1)
