Pro 3.6 unable to read Excel files?
394
11-27-2025 06:02 PM
RTPL_AU
Honored Contributor
Since the upgrade to Pro 3.6 I am often seeing Pro unable to open an Excel file.
Anyone else seeing the same?
I think it is a Microsoft issue as I can read a file that I received a while ago but if I edit it in Excel, save it to a new spot and try to read it with Pro to import a table, I get the red ! and it doesn't show the contents.
ShaneONeill_144
Is this happening with any other Excel files or is it isolated to one?
RTPL_AU
Honored Contributor
Hi @ShaneONeill_144
Multiple files.
ShaneONeill_144
It would be worth reaching out to your local Esri distributor regarding this, they will be able to investigate this further for you.
RTPL_AU
Honored Contributor
Hi @ShaneONeill_144
To the contrary - to reach out this soon into finding something means I will have to spend a lot of time defining and mapping out every scenario where this may take place. A bug will not be lodged unless our locals can reliably replicate the issue - which we've found with some bugs is not possible due to their IT/security/machine/etc configs.
To protect commercial-in-confidence data I will have to create functional replicas of client data and hope it allows the problem to display itself. As you know, Excel files can get corrupted with no visual or functional cue inside Excel but break anything else trying to read them.
My hope is to ask the question here and find that others have experienced it and that Esri is aware of it and have a simple "update this runtime" or "uninstall this Windows update".
The funny thing is - the files work in QGIS and ArcMap so leaning more towards a Pro issue.
As I've said many times before - It seems that with Pro there is always something going on.
